10-20-2010 09:11 AM - edited 03-16-2019 01:27 AM
All,
I need to upgrade my customers Unity Connection 1.2(1) servers to 1.2(1)SR2, however to get there I need to first upgrade to 1.2(1)SR1.
However the upgrade patch 1.2(1)SR1 is not available for download, so how do I get to 1.2(1)SR2?
Any help appreciated :-)
Craig
Solved! Go to Solution.
10-20-2010 09:19 AM
Your best bet is to open a TAC and find out if they can publish it for you.
I thought you could install it directly but the RNs do state you need SR1 as a pre-requisite for SR2.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
10-20-2010 09:19 AM
java
10-20-2010 01:57 PM
Exactly right javalenc, I opened a TAC case and they published the SR1 update for me :-)
Many Thanks
Craig
