Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Unity Connection 1.2 Distribution List
Does anyone have any documentation on setting up a Distribution List in Connection 1.2, I setup the System Distribution List, added Members, but when I dial the number assigned to it it plays the default "Hello welcome to Cisco Unity Connection messaging" Instead of the Recorded Name?
1 ACCEPTED SOLUTION
Re: Unity Connection 1.2 Distribution List
check the number of cti and calhander
u dont need any rule
this sounds unity not reconizing the number
check also the transfered otion in the call handler make send caller to greeting
this number only for managment
u need to creat a callhandler and give it number lets say 2000
and make the recepient of the CH as the distribution list you made in message section
now in you CCM creat a cti route point give the cti port a number as the callhandelr which in our example 2000
and check the check box of forwar all to voice mail and make sure to chose a voice mail profile
in the callhander put what ever greeting yu want this way the left message will go to all distribution list members
good luck
if helps rate
Thanks, but it still plays - the Hello Welcom to Cisco Unity Connection messaging, from a touchstone phone you may dial an extension at any time. Not my recorded greeting? I even setup a Direct Routing Rule and to no avail? I have setup a CTI route point in Call Manager, with Forward all to VM checked and the VM Profile for Connection selected. In Unity Connection I have the same extension which is 2500 as the CTI Route Point as a Call Handler. The Call Handler has the message recipient as Mark Urgent and has the message recipient as the Distribution List, which is the only place I see I can assign the Distribution List.
Hi marwanshawi,
I'm experiencing the same problem. Is it because of the greetings setting in the call handler? In the section After Greetings, what is the correct option for configuring distribution list?
Thanks.
391
