unity connection 1.x
My client wants to upgrade their Unity Connection 1.x box.  Can anyone suggest what I should recommend?  Also if you can share your experience or at least point me to some links that will help me.
Everyone's tags (1)
upgrade to what????
upgrade to what????
java
if this helps, please rate
www.cisco.com/go/pdi
 WEll i am looking for
WEll i am looking for options.  and Direction.  What can i do with my current equipment as far as upgrade is concern?  Surely their is a document or details that help you understand your options with your current equipment.  Or if you have experience, and from it, we will have to decom the current hardware and just simply purchase all new equipment.  We are currently running Call Manager 4.1.  So i guess what ever Call manager 4.1 is compatible with, and highest version of CIsco Unity that we can go to?
I hope that answers your question?  or is it clear as mudd?
Then, you need to mention
Then, you need to mention what HW you're using...
Anyway, most likely you won't be able to upgrade to any currently shipping version on it and you'll have to buy new HW.
Assuming you have CUC 1.2, you might be able to pull some info out from it.
http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
And you CCM version is not compatible with anything currently shipping
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
HW compatibility
http://www.cisco.com/c/en/us/products/unified-communications/unity-connection/datasheet-listing.html
Upgrade/install/configure guides
http://www.cisco.com/c/en/us/support/unified-communications/unity-connection/tsd-products-support-series-home.html
I'd recommend you to engage a partner for this.
java
60
