Unity Connection 2.1
I want to create the Auto Attendant or URA in Unity Connection 2.1.My network have CUC integrated use with MCS7815, I know that the CME is initiated with this configuration through the CUE Editor, but never made the Unity Connection.
Help me to start this setup?
Any help will be appreciated.
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
2 ACCEPTED SOLUTIONS
Re: Unity Connection 2.1
Just create a CTI route point with a DN of 7800, and CFA the DN to VM. Of course be sure that the partition in which the DN resides is visible to the GW calling search space.
Hope that helped, if so please rate.
There is another process of diverting the incoming call to that number:
Say in UC you create the no 778 for auto attendant. Under DN create a DN (say 779) & forward that to 778.
It's extremely easy, configure a system call handler to receive the call.
Then you can create other call handlers to configure branches using the caller input options.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Ok Java Thank's!
How do I upload a custom message?
In Cisco Unity Connection:
Under Call Management Option. you can create a new call handler. In that Call handler, under Edit Option, you can define caller input, i.e. on pressing which key what action should be taken.From there you can send calls to another call handler or system transfer or operator, depending on your choice.
Let me know if it helps...
Ajay
In the media bar you have the option to paste from a file or you can have CUC call you to record the greeting.
java
java
How can I forward icoming call to Call Handlers?
For example:
Icoming call to number 7800,how my gateway forward to my call handler?
I Created a call handler and assinged an extension. But when the caller instead hear my recorded greeting, it's hear the openning greeting.
What can i do for the caller hear the greeting that i recorded in call handler basics page ?
I'm monitoring the call go to correct call handler and after to openning greering instead go to of my recorded greeting in call handler.
In version Cisco Unity Connection 2.1.2.1000-380 have not "call transfer" settings, but "Transfer Option" settings where in parameter "Transfer Calls To:", both options "Greeting" or "Extension" set, the call go to openning greeting after correct call handler. Instead go to of my recorded greeting in call handler.
hi guys
And to create the Auto-attendant!
Just created the Call handler said as I upload the custom message, the only difficulty was to forward the calls for the Call Handler then set a trunk between gateway for Unity Connection.Its working smoothly my URA.
Thanks to all
293
