Unity Connection 7.1, 2x Voice Gateways
We have a Hub and Spoke model for IP Telephony.
Site A holds CUCM and CUC. Site B Cisco IP Phones registers to Site A via MPLS.
I have setup all calls for Site B to come in and out of Site B local Voice Gateway. My problem now is when I have a phone at Site B with a Unity Connection user setup using the caller input feature destine to a mobile, how do I force the mobile called number to go out of Site B Voice Gateway when the calling party press 1 (caller input) to mobile?
Each Voice Gateways have separate ISDN DIDs, no overlaps. CUCM to VG Site A and B is via H.323.
Re: Unity Connection 7.1, 2x Voice Gateways
You can use local route groups if available in your CUCM version or adjust CSS and partitions fromVM ports CSS
java
if this helps, please rate
www.cisco.com/go/pdi
Thanks for the reply.
So normal Route Pattern will be use from CUC to CUCM to Site B Voice Gateway?
The reason why I'm asking is I wasn't sure if the original called number in CUCM with the Site B partition/CSS is retain once the calling party is transfered to CUC then back to CUCM for caller input 1 to be transfered to mobile.
236
