Community Member
Unity Connection 7.1.3 Ports dont fail to second CUCM in group
CUCM 7.1.5 has device pool with two CUCM's this is applied to VM ports in CUCM under device Information.
Issue
When the primary CUCM server is shut down calls cant be made to unity connection
Shouldnt the ports be auto registering to second CUCM in the group?
Any known issues?timers etc
Allan
1 REPLY
Super Bronze
Re: Unity Connection 7.1.3 Ports dont fail to second CUCM in gro
You need to manually configure the list of servers CUC uses:
Log into cuadmin, then go to 'Telephony Integrations', then 'Port Group' on the left. CLick the 'Edit' menu, then 'Servers'. Update the list of CCM servers to match your CM Group configuration there.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
210
