Community Member
Unity Connection 7.1.3 SMTP relay
I have SMTP relay running, and voicemail can be sent to email inbox
i have two questions
Q1, is there any way to preserve the MWI feature with SMTP relay? currently, as soon as i left a voicemail, it relay to email and the MWI never turn on
Q2, is there any option to allow end user to turn the relay on or off?
Re: Unity Connection 7.1.3 SMTP relay
1) Possibly, but you would need to look at 3rd-party MWI such as Geomant to see what capabilities are there.  Inherently, with SMTP relay and CUC - No.
2) No.
Please rate helpful posts!
Community Member
1. I think you don't need a 3rd party tool. Go in unity conncetion Admninistration>>User, Select a User, go to Edit >> Message Action, select "Accept and relay the Message" for the message type you need.
I set for me the relay and accept options and set as notification devices mobilphone and SMTP.
If I got an voicemail the unity call my mobile phone, set th MWI to ON and send an email. It's to much I know, but it's only for test purrpose.
2. I don't know if it possible that the use turn relaying on and off. But test the personal transfer rules for user. You must enable it for the user at Unity Connection Administration >> Class of Service, Select the Class of Service which the users are members, Check the box "Features >> Allow Users to Use Personal Call Transfer Rules". At this time the user can login to personal transfer rules at the unity connection user page entry.URL is: http:///ciscopca
Maybe at this way is a possibilty to turning relay on or off.
Sure, you could rig some sort of notification with notification device techniques but I read the question as more of asking what is the inherent capability associated with using the relay parameters.  The best way I can sum this up is to refer you to this blog that my colleage, Bill, wrote:
It gives you the in's and out's of the Relay Only vs. Store and Forward options of CUC including how MWI behaves.
