VIP Super Bronze
Unity connection 7.1.5 Auto attendant greetings issue
Guys,
I am trying to use UC fotr auto attendant for a simple AA. I have created a call handler, recorded the appriopriate greetings (welcome greeting) on the call handler. However each time a call comes into the CH, its playing the recorded name greeting eg..
What I mean is this..The recorded greeting is "welcome to XYX, press 1 for this, press 2 for that"
When a call comes into the CH, users hear " sorry...welcome to XYX, press 1 for this, press 2 for that".
So unity connection is playing the greeting as a user recorded message. eg "sorry Deji Okanlawon is not available"
I have recordeda diffrenet standard greeting, created a call routing rule to send a callf or the CH to greetings, but it keeps playing the sorry and then the prompt.
Ideas guys?
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
  • IP Telephony
Re: Unity connection 7.1.5 Auto attendant greetings issue
Have you tried recreating the call handler from scratch?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
VIP Super Bronze
Java,
I created another CH and the same thing happened. So its a strange issue. because Initially when I had this problem, I selected to use "My personal recording" on the greetings instead of system default and it worked and all of a sudden its not working!  Should I escalate this to TAC beacuse I believe this shuld be simple enough
Hall of Fame Super Red
Hey Deji,
Hope all is well my friend
Can you try setting up a new CH like Java nicely suggested. Do not record
a recorded name at all. Then from greetings page choose the Alternate Greeting
Enabled with "no end date" and record your Personal Greeting at this point. Then test
Cheers!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
VIP Super Bronze
Rob,
Thanks. Very weird one this one. I have done just that. I created a new CH, without a recorded name and then recorded a standard greeting. That did tyhe trick. Strange!
Hey buddy!
Nice work Deji Sometimes just going through the process a gain makes all the difference.
Cheers!
Rob
PS: are you using ATM for Unity Connection for creating the Call Handlers. It's really
a fine tool!!
367
