Unity Connection 7.1(5) - Voice enabled directory call handler issue
I'm trying to configure a voice-enabled directory call handler in Spanish, but it seems is not possible to change language for voice-enabled directory call handlers, the option dissapears when you check the voice enabled box.
I can't find the doc where this is said. The sysguide only says its possible to change the language, but no restriction is mentioned.
1 ACCEPTED SOLUTION
Re: Unity Connection 7.1(5) - Voice enabled directory call handl
HI Segrana,
Unity Connection’s voice enabled directory handlers will only play in US English regardless of the system language on CUC.
This is by design.
I think this warrants a feature request. (can be created by going through your account team)
Kurt
HI Segrana,
This is by design.
Kurt
Thanks Kurt, I was able to find the restriction in documentation. Strangely it is in the hardware reference guide.
264
