unity connection 7.1 forwarded call
there are phones A and B (both with voicemails) and A  is forwarded to B. Is it possible to make that when B does not pick up  the call, the message will be left in B's voicemail?
No, because voicemail settings will be followed as per Phone A config, which will point towards Phone A's VM box.
Pls rate the post if it helps.
GP.
You can user either the original called number (A) or the last redirecting number (B) to select which VM to reach, however this is a global setting.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
156
