Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
unity connection 7.1 with CUCM business edtion 7.1
I have already added Unity connection user around 172 user, now when I try to add as user the unity says the following error " the request operation is probhited".
Could please some one light me what is the problem and workaroung for this.
Re: unity connection 7.1 with CUCM business edtion 7.1
Do you still have free licenses????
java
if this helps, please rate
java
www.cisco.com/go/pdi
I have lic file in Unity, the problem is the particular enduser does not have CTI enable user, once we did, it works fine.
Thanks for the reply
119
