Community Member
unity connection 7 - which service controls login authentication?
Our unity server crashed this morning and no longer allows anyone to login to the admin page. I can't restart the server during production and was hoping to just be able restart a service? I am able to SSH into the server however. Anyone have any ideas on what services control the http admin page authentication?
Everyone's tags (1)
Hall of Fame Super Silver
is your UCON server integrated with LDAP?
Chris
Community Member
Re: unity connection 7 - which service controls login authentica
yes it is. though I have a local account also that I can use for adminsitration.
Ensure the LDAP server is accessible then, there is nothing from servicibility point of view to reset to help this.  There is always a master local application user that is not using LDAP which would allow you to review LDAP integration/configuration.  Any chance of getting that username/password and loging in with it?
Chris
Community Member
is this on the serviceibility page?
382
