Unity Connection 8.5.1 -> Language problem message settings
i have a little problem with recording messages. If i changed the Message Settings language on the User (e.g French or German) the system said after saying the message that the system is not ready to handle calls.
If i use English it works and the user MWI is on and the message is on the voicemail. But i need to change the message settings language that the caller hear French or German.
See attached screen what i mean.
Is this maybe a known bug in Unity Connection 8.5.1.10000-206 ?
Best regards
Thorsten
1 REPLY
ok, i will try this thread. :-)
-> https://supportforums.cisco.com/thread/2095827
273
