Unity Connection 8.5.1 Services - Cannot seem to activate
I installed CUC in vmware workstation 8 and looking at the first attached file (Service Activation.png) I cannot seem to get the Cisco Serviceability Reporter to get activated even though I already check the box and save
Also at the first attached file (Service Activation.png) the service Cisco AXL Web Service and Cisco UXL Web Service is activated, but looking the the second attached file (Feature Services.png) these services are nowhere to be found under the Database Admin Services. But I can successfully import users from CUCM to CUC
Is this normal in CUC which is also the same in MCS hardware? Or is it a bug in VMware? Or Bug in CUC 8.5.1?
By the way I'm using CUCM 8.5.1 and CUC 8.5.1. But I look at my CUCM 7.0.1 and CUC 7.0.1 and everything is fine
Mark
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Mark,
This is normal and is exactly the same on our setup
that uses MCS boxes
Cheers!
Rob
Hi Mark,
Can you please check these via CUCM > Cisco Unified Serviceability rather than
Unity Connection > Cisco Unified Serviceability
Cheers!
Rob
Re: Unity Connection 8.5.1 Services - Cannot seem to activate
Hi Rob
Upon checking CUCM --> Cisco Unified Serviceability, the AXL Web Service is activated and started. But not in CUC, is this normal? Or only in vmware environment?
Hi Mark,
that uses MCS boxes
Cheers!
Rob
Thanks Rob for the clarification
691
