Unity Connection 8.5.1 - upgraded ESXI from 4.1 to 5.1
Hello All,
We just completed upgrading the ESXI version on one of our UCS c210 m2 servers.  We went from v4.1 to v5.1.  We are currently running CUCM, Unity CXN, and Presence on the server that we upgraded.  The other UCS was not upgraded and is running the subscriber version of the same applications.
After the upgrade completed we can not access UNITY Connection.
We are getting "Database Communication Error."  The subscriber is still working so we are still in service, but we are afraid that the database has become corrupted and we are seconds away from complete failure.
Please let me know if anyone has encountered the same issue or has any suggestion.
AK
Can the CUC Pub and Sub reach each other?
Yosh
HTH Regards, Yosh
They cannon see each other.
I haven't seen any document for Unity Connection 8.5.1 regarding upgrading ESXI.  Just wondering if anyone can provide a link or doc outlining what is required.
Thansk,
AK
Did you verify that the vSphere Host NICs are connected and checked. Also verify that you can ping the vSwitch management address.
Yosh
HTH Regards, Yosh
Hall of Fame Super Silver
Did you read this:
Patching and Updating VMware vSphere ESXi
  • In general, Cisco Collaboration app versions only mandate the Major/Minor versions of ESXi they require/support.
  • Guest OS support - Cisco Collaboration apps that require a minimum Maintenance release (e.g. "5.1 U1" as minimum instead of "5.1" as minimum) for the application to be supported will explicitly call this out on their product detail pages.  When in doubt, consult Cisco Plan, Design, Implement (PDI) HelpDesk or Cisco TAC.
  • Hardware support - For a Major/Minor version of ESXi supported by Cisco Collaboration apps, recommendation is to use the latest Maintenance release that is also supported/recommended by the server vendor (and storage vendor if deploying on NAS/SAN).  To help determine if a patch or Maintenance Release of ESXi "can" or "should" be deployed, follow the guidance from these sources:
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
UCXN 8.5 is supported with ESXi 5.1 per:
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unity_Connection#Version_8.5.28x.29
Chris
Can you SSH to it?
Can you console in from vSphere?
Chris
Yes we can ssh to it.
Did you verify the status of the CUC VM and the network settings? Can you console into the CUC server?
Yosh
HTH Regards, Yosh
Re: Unity Connection 8.5.1 - upgraded ESXI from 4.1 to 5.1
Did you restart the server to see if that fixes it?
What is the database status showing from CLI?
181
