Community Member
Unity Connection 8.5 - Cannot delete user template
A new user template 'base-voicemailusertemplate' was created based on the default 'voicemailusertemplate' (it looks like these are now coupled via a pointer, if I select the default one, it's alias is the same name as the new custom one I created). Both of these user templates have the selection check box greyed out.
How can I delete the new one that I created?
I cannot find anything in the support community or the bug tool kit on this.
Unity Connection version 8.5.1.10000-206
Andy
Everyone's tags (2)
Community Member
TAC Resolved:
Known issue in 8.6, not seen in 8.5 until this case.  Newly created template based on default created a new alias that simply referenced the default object id.  Result, any change to either changed both.  TAC ran CLI instruction to delete alias and NOT object id.
Hall of Fame Super Red
Hi Andy,
Thanks for posting back with your results here +5
This type of kind follow-up will always help someone else down the road
Good stuff!
Cheers!
Rob
PS: is there any Bug ID for this?
301
