Unity Connection 8.5 - Full Mailbox receipt - Reason Code 422
Hello Community,
I am hoping to get your input regarding messages that Users receive AFTER they leave a voicemail message for another.  If the Mailbox of the target is full, the caller does not receive a notification until after they leave their message.  This is the full message that the Caller recieves "A receipt - your message to ---  sent today at 2:33PM could not be delivered - reason code 422 - message
was not delivered because the recepients mailbox is full."
Many thanks!
Tom
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Tom,
I know what you're saying
For External callers only;
Message Storage > Mailbox Quotas " "
For Internal calls you can turn off the receipt only;
When a user tries to leave a message for another user whose mailbox has exceeded the send/receive quota, Connection allows the user to record and send the message. However, if the mailbox for the recipient is full, he or she does not receive the message, and if the user account for the recipient is configured to send non-delivery receipts when message delivery fails, Connection sends the message sender a non-delivery receipt.
On User Basics page;
Cheers!
Rob
Hi Tom,
It sounds like you may be hitting this bug;
CSCto07341 - NDRs should only play back NDR reasons in english, not numeric codes
Description
Symptom:
For Non-delivery-receipt (NDR) messages, Unity Connection plays a reason code and explanation. For example: "...the message was undeliverable because of code 422 - the mailbox was full".
It would be preferred if the code itself could be disabled and only the explanation played.
Conditions:
Workaround:
None.
Details
1st Found-in:                          (1)
8.5(1)
Status:
Open
Last Modified:
Jun 03,2011
Product:
Cisco Unity Connection
Platform:
Dependent
Severity:
6 - enhancement
Cheers!
Rob
Hi Rob,
Thanks for your input.  I am wondering if there is a service paramater that I can change that will disable this message as it is sent to to Unity CN inbox of the Caller after they successfully leave their message.  Or, how can I set up a parameter where the caller hears the mailbox for the user they are calling has a full mailbox first? This will discourage the caller from leaving a message and will reduce frustration.  Make sense?
Many thanks!
Tomk
Hi Tom,
Cheers!
Rob
Thanks Rob!  Many thanks for your help!  Final question; Is there a service parameter I can utilize to change this for all internal calls or would I need to use Bulk Edit?
Kind regards,
Tom
Hi Tom,
You are most welcome my friend
Change it on the User Template and it will catch all "newly created" users, and then Bulk edit
for all the existing users.
Cheers!
Rob
2793
