04-20-2012 09:20 AM - last edited on 03-25-2019 08:14 PM by ciscomoderator
I have a customer that just wants the system default standard greeting to use extensions for everyone
i.e. "Hello, you have reached extension 1234, please leave a message".
I have changed the system default to use the extension as opposed to the text to audio of the name.
(uncheck Advanced->Conversation->
Unfortunately, I have many subscribers that have recorded names so those need to be cleared. I have searched the
manuals, forums, online,... no luck.
Any ideas? Hope fully something very easy under my nose :-)
Andy
Solved! Go to Solution.
04-20-2012 09:39 AM
Hi Andy,
The best way with Unity Connection is with the use of this excellent tool from
the great suite of Unity Tools (use the ** reset" feature **). I just it out for this purpose
and it worked like a charm
Unity Connection Bulk User Delete
For resetting users you have the option of emptying the mailbox, resetting greetings, deleting voice names, resetting passwords, removing private lists and a number of other options you may choose. For installations where the user base “changes over” frequently such as schools this may be a nicer option. This option is also allowed for CoRes installations since it does not involve the removal of user objects from the Connection database.
http://www.ciscounitytools.com/Applications/CxN/BulkUserDelete/BulkUserDelete.html
Cheers!
Rob
04-20-2012 09:39 AM
Hi Andy,
Cheers!
Rob
04-22-2012 11:10 AM
Thanks Rob!!!!
Performed first few and it worked like a champ!
