Unity Connection 8.5 Unified Messaging
Hello all,
I have a customer that has Unity Conneciton version 8.5 which is integrated with Exchange 2010 for Unified Messaging.
I'd like to know if it's possible that when a voicemail is left in an extensions voicemail box; the message can be sent to an email distribution list instead of just to the user's Outlook Inbox.
thank you.
Patrick
  • IP Telephony
1 ACCEPTED SOLUTION
VIP Super Bronze
If you meant an Exchange Distribution List instead of a Unity Connection Distribution list it can be accomplished using Message Actions; just set it to Relay or Accept and Relay and specify the SMTP address of the Exchange DL.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmac040.html#wp1330388
Please remember to rate helpful responses and identify helpful or
Gold
Re: Unity Connection 8.5 Unified Messaging
Hi Patrick
One way of doing this (and I'm not saying this is the only way) is to use a Call Handler. The message recipient on the Call Hander can be a Unity Connection distribution list which can include multiple target inboxes.
You can't use this technique on "normal" UC mailboxes - it has to be a Call Handler.
I've used this a few times, and it works fine.
HTH. Barry
Barry Hesk
Intrinsic Network Solutions
VIP Super Bronze
Thank you BOTH for the quick replies; I did mean an Exchange Distribution List.
Patrick
482
