Community Member
unity connection 8.5
                   HI
I'm using unity connection 8.5 versoin in HA mode.
problem is , I'm not able to connect to unified serviceability in subscriber. publisher is fine.
and in application administration page I'm able to login but not able to access any thing in the page like call hanler and users, templates.
please suggest some solutions.
Community Member
also I'm getting the below error
i connect to publisher and login tnen unified serviceability then i select sunscriber .now I get the below error.
Unable to communicate with service control center. The password for Administrator (the administration account that was created during installation) may be locked out or expired.
publisher is fine.
From the command line of the Publisher, can you run "show cuc cluster status" and post the output.
Hailey
Please rate helpful posts!
Community Member
HI,
thnaks for the reply,
please find the
show cuc cluster status from publisher.
admin:show cuc cluster status
ACE_File_Lock::ACE_File_Lock: Permission denied /dev/shm/CCM_GENstatusLock_0
Server Name    Member ID  Server State  Internal State  Reason
srxblrunity99  0          Primary       Pri Active      Normal
drxblrunity99  1          Secondary     Sec Active      Normal
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_ciscounity_pub      100 Active   Local           0
g_ciscounity_sub1     101 Active   Connected       0 Oct 20 13:23:52
SERVERS
Server            Peer              ID   State    Status     Queue  Connection C
hanged
g_ciscounity_pub  g_ciscounity_pub  100  Active   Local      0
:52
g_ciscounity_sub1 g_ciscounity_pub  100  Active   Connected  0      Oct 20 13:23
:52
                  g_ciscounity_sub1 101  Active   Local      0
STATE
Source            ER               Capture          Network          Apply
                  State            State            State            State
g_ciscounity_pub  Active           Running          Running          Running
g_ciscounity_sub1 Active           Running          Running          Running
Purple
the dbreplication seems to be OK.
Did u try utils service restart Cisco Tomcat from CLI of OS Administration from Subscriber?
regds,
aman
Community Member
HI,
Thanks for your reply.
restarting Tomcat service needs to get approval. I try to do that and update .
I can able to access UC administration page but after logging in I'm not able to access anything inthe page.
I changed the password from publisher and try but no luck.
Community Member
Checking the "never expire" option on the CUAdmin account fixes the error message and access to Service Management.
Please refer to the below link for more information
https://supportforums.cisco.com/thread/2109854
Sandesh Rao
Please rate helpful posts.
FYI - you should not see this in your cluster output:
Community Member
HI David,
Is there chances for getting the situation worse if i restart the cluster?
because as of now voice mail is working fine.
problem is Backup is not happening and not able to login unified serviceability in only subscriber.
One more we don't have proper backup also.
please suggest restarting will affect worse on the voice mail functionality.
I think this is because of database gone read only mode or some thing.
388
