05-24-2012 02:29 AM - edited 03-16-2019 11:19 AM
I am attempting to install a new Unity Connection cluster and when I boot to the DVD supplied I am not being prompted to select from Unity/CUCM or CUCM Business edition, it boots straight into CUCM without giving me any options in the product deployment selection screen.
The message "The Cisco Unified Communications Manager product swuite will be installed"
Has anyone experienced this before and has a solution?
My experience has always been with Unity running on a Windows OS.
Carl Messer
Solved! Go to Solution.
05-24-2012 02:48 AM
Hi Carl
Unity, CUCm and CUCMBE are all supplied on the same DVD. If you don't get options, it's because your server does not meet the required specification.
Aaron
05-24-2012 02:48 AM
Hi Carl
Aaron
05-24-2012 02:51 AM
Thanks Aaron, it appears my partner has sent a server that does have enough resources to run Unity.
Thanks for your prompt reply.
Carl
05-24-2012 02:55 AM
No problem!
I think it's probably the increased RAM requirement on 8.6 that caught them out...
Principal Engineer at Logicalis UK
10-31-2014 08:34 AM
I found this post and was very useful to me, so I will add that if you are experiencing this problem while attempting to use an .ISO with VMware, you must assign at least 4GB RAM for Unity Connection to be available. Check the supported platforms section for the documentation guide. For example:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html
