12-18-2011 02:05 AM - edited 03-16-2019 08:35 AM
hello
i install on cisco ucs server vmware 4.1 with cucm 8.6 and unity connection 8.6
the sinc between them is fine
the networking between them and the gateway voice is fine
the problem is when i try to leave a massege to voice mail the unity do not recive it and mwi is off
the dtmf is also fine
please open the attach file( connection remote port result)
help
tk
shoham
Solved! Go to Solution.
12-18-2011 10:20 AM
Can you clarify following things ?
1. Are you sure if the CUC doesnt receive the VM at all ? If yes, pls explain how you confirmed it ?
2. Is it the case that , CUC receives the VM but the MWI light doesnt turn ON ?
GP.
12-18-2011 10:20 AM
GP.
12-25-2011 03:15 AM
hay
its fine now
i erase the voice ports and configure them again and it works
tk
12-25-2011 03:23 AM
glad to hear that.
Happy Holidays !!
GP.
