Community Member
unity connection 8.6 problem
hello
i install on  cisco ucs server  vmware 4.1  with cucm 8.6  and  unity connection 8.6
the sinc between them is fine
the networking between them and the gateway voice is fine
the problem is when i try to leave a massege to voice mail the unity do not recive it and mwi is off
the dtmf is also fine
help
tk
shoham
1 ACCEPTED SOLUTION
Can you clarify following things ?
1. Are you sure if the CUC doesnt receive the VM at all ? If yes, pls explain how you confirmed it ?
2. Is it the case that , CUC receives the VM but the MWI light doesnt turn ON ?
GP.
GP.
Community Member
hay
its fine now
i erase the voice ports and configure them again and it works
tk
glad to hear that.
Happy Holidays !!
GP.
278
