09-03-2013 10:54 AM - edited 03-16-2019 07:11 PM
In Cisco Unity Connection version: 8.6.2ES25.21900-25, is there a way to reset just the user's NAME, instead deleting the entire mailbox account and recreating it? We reset a bunch of new users passwords, set to change at next login. However, the old user's name is still on the greeting. Any help is greatly appreaicted. Thanks so much.
Solved! Go to Solution.
09-03-2013 11:05 AM
Hi Joseph,
Hope all is well my friend!
The best way with Unity Connection is with the use of this excellent tool from
the great suite of Unity Tools (use the ** reset" feature **).
Unity Connection Bulk User Delete
For resetting users you have the option of emptying the mailbox, resetting greetings, deleting voice names, resetting passwords, removing private lists and a number of other options you may choose. For installations where the user base “changes over” frequently such as schools this may be a nicer option. This option is also allowed for CoRes installations since it does not involve the removal of user objects from the Connection database.
http://www.ciscounitytools.com/Applications/CxN/BulkUserDelete/BulkUserDelete.html
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
09-03-2013 11:05 AM
Hi Joseph,
Cheers!
Rob
- Bob Marley
09-03-2013 11:18 AM
All is well my hockey friend - especially since the season will be starting in a month
Thanks - I remember the Bulk User Delete from before - and we cannot run/install it on our computers - haven't looked into it in detail. But if I ever get it up and running I am sure it will make life easier. Thanks again.
09-03-2013 11:44 AM
Hi Joseph,
Yes this would make your life much easier
You could just get the users to re-do the recorded name themselves which
doesn't seem too arduous.....
Change recorded name | 4 3 2 |
Cheers!
Rob
PS: Woot! Woot! Hockey in 1 month! Hopefully the SaddleDome is ready
to go after the bad flooding here in June (fingers crossed!)
- Bob Marley
09-03-2013 12:08 PM
So very true - but that does require them to do something - lol - thanks again. I will suggest this to the next caller.
