Unity Connection 8 block Transfer to Specific Alternate Contact Number under caller input
Where in Unity can we defineapply specific dialing rules that block numbers being dialed [patterns] for Alternate Contact Numbers [for subscribers]
For Example user Greeting has press "2" to reach my mobile yet this has been routed to Bermuda
The deafult Restriction Tables have all been blocked yet this has no impact on transfers to [Alternate Contact Number]
Default Fax
Default Outdial
Default System Transfer
Default Transfer
Excluded Extensions for Automatically Added Alternate Extensions
1 REPLY
Re: Unity Connection 8 block Transfer to Specific Alternate Con
If the users are setting their own dial out numbers over the phone, then they have to pass the transfer restriction table for that user's (under Restriction Tables -> Transfers).
Kind regards,
Craig
Please rate helpful posts!
347
