Community Member
Unity connection 9.1 - Call Handler - remove -' wait while i am tranfering your call''
Hello All ,
i have configured call handler on unity connection 9.1 is playing . i need to remove this prompt because of miss match of  language.
please advice
Hall of Fame Super Silver
Uncheck "Play the "Wait While
Uncheck "Play the "Wait While I Transfer Your Call" Prompt" under the transfer rule of the destination handler/user.
Community Member
thanks for your reply Chris.
i have done the same . but no luck
i have uploaded the scrnshot of tranfer rule page .
please advice .
Community Member
 Hi Chris , belwo is my
 Hi Chris ,
belwo is my scinario
after welcome greeting -- press 2---route to English menu.
english menu---caller input --- press 2 --- routeto markeeting """ here we have to remove this default unity recording ----- wait while trafer your call """"
Note : transfer from greeting to greeting this recording is not there  but from greeting destination Ext (CUCM-  DN) this recording is being played . which i have to remove
Desired condition : after caller input call shoud directly transfer to the mentioned DN.
if you need any futher info please let me know
Community Member
I know this is an old post
I know this is an old post but I found it helpful and I wanted to say thanks! I had been looking in the Call Handler transfer rules to try to disable this message. It was actually on the destination user transfer rule that I had to un-check the "Wait while I transfer your call" prompt.
Hall of Fame Super Red
Hi Aslam,+5 to my friend
Hi Aslam,
+5 to my friend Chris here for his good thoughts on this dilemma.
Does the Marketing number you are transfering to have a mailbox? If so, I would try;
Caller Input > 2
User with mailbox > whatever the Marketing mailbox is named
Attempt transfer (not go directly to greetings)
If I use this methed rather than Caller Input 2> Call Action> Transfer to alternate contact number > Marketing number I can get rid of the "wait while I transfer" prompt :)
