Unity Connection 9.1 for HA
Hi, existing I only running 1 unit Unity Connection and yesteday i had add in the subscriber and have configure neccesary parameter for HA. During I test down the publisher and can saw subscriber had take over the role as primary, but I fail to reach voice mail. Then I check CUCM and found the voice mail registration are unregister. Then I go to Unity connection serviceability to check the Unity port and found the port for subscriber is 0. Here is my question:-
 - Is it normal which have 0 port?
- If this is not normal, how can I make voice port on subscriber same to publisher is 24 port?
- Is it HA need license?
- Is it I need to recreate the voice mail port at CUCM?
Please advice.
Thank you.
John
1 ACCEPTED SOLUTION
VIP Super Bronze
Port capacity depends on the
  1. Port capacity depends on the hardware. Assuming VMware since this is a new deployment which means port capacity is dependent upon the OVA you used and whether you have enabled G.722/iLBC or not.
  2. You need to install a license on the subscriber server. For this you need to place an order even though the HA server is free, you still need a PAK.
  3. Yes, see answer two.
  4. The subscriber will have it's own port group within CUC and additional voicemail ports in CUCM.
    http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/integration/guide/cucm_sccp/cucintcucmskinny/cucintcucmskinny070.html#wp1097184
Please remember to rate helpful responses and identify helpful or
VIP Super Bronze
Hi Jonathan,Thanks for your
Hi Jonathan,
Thanks for your response and answer.
62
