Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Bronze
Unity Connection and multiple clusters
I have an 8.6.2 cluster with unity connection 8.6. I am deploying a second cluster and am trying to use the Unity connection on the first cluster via a trunk.
I have configured a SIP trunk between the clusters with QSIG tunnelled protocol and am able to leave messages , however MWI doesn't work
I have also tried with an ICT trunk and same results.
I'm now stuck as i believe this should work but am not sure on MWI config.
The MWI numbers on the second cluster , what should they be, i have read that you don't actually need them??? i have tried with and without and nothing changes
VIP Super Bronze
I am not sure why you wouldn
I am not sure why you wouldn't need MWI numbers, I have a sip integration and I definitely use them.
Few things to check
1. Your sip trunk security profile needs to have the ff: checked
accept out of dialog refer
accept unsolicited notification
accept replaces header..
2. The inbound css on your sip trunk to unity connection needs to have access to the pt of mwi number.
3. keep it simple, use only sip trunk, I am not sure why you need qsig tunnelling, unless you need it for specific requirements, I will only use a sip trunk..
4, have you tried dialling the mwi number form an ip phone? does it work?
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Bronze
1. I will check2.The unity
1. I will check
2.The unity connection integration to first cluster is actually SCCP but  I will check the CSS on the ports
3.If you read all the documentation it all mentions using QSIG tunneling to carry MWI between the callmanager clusters
4.yep
Bronze
So i set this up in my lab to
So i set this up in my lab to replicate what i wanted to achieve
UnityConnection 8 ---SCCP----CCM862SU2 -----SIP Trunk ------CCM862SU2
Basic config on the sip trunk , just added QSIG as the tunneled protocol.
It worked first time..............  Can't see why this doesn't work on the production cluster.
You don't need MWI configured on the second cluster , it all just seems to work.Will post again when i figure this out (hopefully)
VIP Super Bronze
Mark,Thanks for the update.
Mark,
Thanks for the update. (not sure if you remember me though :))
Bronze
sorry deji didn't recognise
sorry deji didn't recognise you're name , yes i do remember you , trying to forget RBS :-) though
anyway , sorted my issue, made a stupid mistake on the mailbox configuration.(Wrong phone system) once i changed that it worked a treat.Very easy setup.
VIP Super Bronze
Thanks Mark for the update (
Thanks Mark for the update (+5). Hope you are well
120
