unity connection bulk update greeting
Hi All,
i am currently using CUC9.1.2, and reg with 270 users.
And right now we are plan to update  their greeting to standard company greeting for everyone. is any way that i can bulk admin to do it instead to config it one by one.
thanks alot
simon
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
You should be able to select the users, press the bulk edit button, then go under edit --> greeting --> select standard recording --> check the checkbox next to greetings and use the play/record applet to upload your greeting or record it.
HTH,
Chris
HTH,
Chris
Thank You Very Much!
276
