Unity Connection: Change the after Greeting options as a user
Daniel Flieth
Hi guys,
i want to know if it is possible to change the after greeting options from my own Mailbox as a user (from phone or pc)
As a user i want to setup if there should be a recording option or if i want to forward the call to a special number or if the call should be hang up.
Best Regards
Daniel
Jaime Valencia
No, you cannot configure the after greeting actions if you're not logged into the admin page
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
