Unity Connection DayLight Saving
Hi All
I have a Unity Connection server running on 1.2(1) SR2 with  1.2(1)ES69 applied as well. After Australian daylight savings, all VMs are an Hour behind. Base OS is 2003 SP1 and time is correct on it as well as call manager servers. TImezone is correct in VM server as well. Any suggestions? I cant see any patches released as per this version from Cisco.
Thanks a lot.
Re: Unity Connection DayLight Saving
anyone?
Hall of Fame Super Red
Hi Aman,
According to the first Bug listed below the fix is in 1.2(1)ES91
Unity Connection
CSCsl88526
CSCtc25326
CSCsl88526—DST:
Australia has extended
Daylight Saving Time in
2008
CSCtc25326—DST:
Australia rejects
for Oct 2009 Symptom
https://www.cisco.com/application/pdf/paws/100509/au_dst_recommendations.pdf
Cheers!
Rob
Thanks Rob
Apparently,  i cant find 1.2(1.0)ES91 in downloads section. it goes as far as ES65. You think  i need to TAC this?
Aman
Hi Aman,
Yes, I would open a TAC case
They should be able to hook you up with ES91 or a
viable workaround.
Cheers!
Rob
762
