Unity Connection Directory Handler ISSUE
Hi all,
Before all i'd like to thank all the members of this forum for their help.
So i'm trying to configure Unity CX2 and now i'm on the final step which consists of the creation of an Interactive Menu, every think is OK except the fact that i want to set up a "Call By Extension" And i don't know how i can do such think since i know that it is the Directory Handler but it always prompt me to SPELL the username.
Anyone has an idea how i can do that?
I have tried to uncheck:
Voice Enabled and Play All names and then i have reduced the timouts for CallerINPUT to its minimum however it's the same it play:
Please spell the first and last name,for Q press 1 for Z press 2 then after One Sec it says IF you would like to enter an extension you may do so now.
I WANNA PLAY ONLY THE LaST PART :)
Hipe someone can helps me
Thanks for all
1 ACCEPTED SOLUTION
Re: Unity Connection Directory Handler ISSUE
Seifeddine-Tlili,
You can Disable Spelled Name Searches, under Advanced/Conversations.
Hope this helps, Please vote below if so.
Justin
aie aie i'm stuck can anyone plz help me i'll really appreciate it
thanks a lot
VIP Super Bronze
I am not sure its possible to change the prompt of the directory handler. Its a single wav file, so you cant break it up...
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Seifeddine-Tlili,
Justin
But it's related to the Directory Greeting not the opening greeting
Thanks for all
Can you please tell where i can found Advanced Conversations
thanks again
262
