Unity Connection - Directory handler (speedial or softkey)
     I have been trying for a few days and I cannot figure out if this is possible.. I love the voice system directory in Unity Connection. I'm trying to setup a speed dial or softkey to the directory handler so that we can access it for our corporate extensions. I would rather not tell everyone they have to go through a menu to get to this feature. Is there a way to create a softkey or a speed dial that takes you straight to the directory handler?
We are running Unity Connection 7.1
CallManager 4.2 (soon to be 7.x)
Thank you in advance,
Raul
1 ACCEPTED SOLUTION
Re: Unity Connection - Directory handler (speedial or softkey)
Easy task, first of all we do not support custom softkeys.
Now, all you need is a speed dial.
CTI RP with CFA to VM to match the speed dial.
Create a call routing rule for forwarded calls in CUC to catch those calls and send those to a Directory Handler.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
that was it.. thank you!
Nice.  That was exactly what I needed.  Now to integrate it with Cisco Mobile 8.0!
Thanks java!
591
