09-08-2011 01:18 PM - edited 03-16-2019 06:54 AM
I have an situation where users on my Unity 8.5.1 server are deleting their messages, but the aging rule is not emptying their "deleted items" folder (not sure if I am explaining this right) causing users to recieve "mailbox full". Cisco TAC says this is a known issue for some users and recommend that we upgrade to a newer release of 8.5 or 8.6. The issue is our long change management process, I need an interim solution till we can upgrade. Asking users to manually empty their mailboxes is not an option, we need away to do this from a sysadmin level.
Sam
Solved! Go to Solution.
09-09-2011 06:41 AM
Hi Sam,
Just to add a note to the great tips from Shalu (+5 )
I think the only workaround until you upgrade would be to follow these steps;
When subscribers delete voice messages within Unity Connection, the messages are automatically moved to the Deleted Items folder. The issue is to find a way to force Unity Connection to automatically erase the voice messages without moving the messages to the Deleted Items folder.
Complete these steps in order to resolve this issue:
Choose Class of Service in the left navigation pane.
Choose the class of service and the users who are assigned to that particular class of service in the list.
Navigate to Message Options, and check the Delete Messages without saving to the Deleted Items folder check box.
Note: The default setting for this option is disabled (unchecked). Check this check box to indicate that Cisco Unity Connection permanently removes messages when users who are assigned to this class of service delete them. Uncheck the check box to instead have Cisco Unity Connection to move deleted messages to the Deleted Items folder, which allows users to retrieve them later.
http://www.cisco.com/en/US/products/ps6509/products_tech_note09186a0080a63009.shtml
Cheers!
Rob
09-08-2011 10:45 PM
Hi Sam,
Have you tried to Configure message aging to permanently delete messages in the Connection deleted items folder. and Configure message quotas, so that Connection prompts users to delete messages when their mailboxes approach a specified size.
The possible workaround could be
1) Increase the amount of messages you can have in your mailbox by increasing mailbox quotas (Message Storage > Mailbox Quotas.).
2) Decrease the amount of days to wait before permanently deleting deleted items out of the deleted items folder.
In CUC admin page Message Storage > Message Aging Policy)
Also have a look at the section Where deleted Items Go in the below URL http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/unified_messaging/guide/85xcucumg020.html
Tx,
Shalu
09-09-2011 06:02 AM
Shalu,
Thanks for your responce. Just to clarify, the users are deleting their messages. The system is not cleaning up after. We tested and if the user logs in via CiscoPCA and does the empty "Empty Deleted Items". It clean up the voicemail box and reset the values.
We don't want users to use CiscoPCA, becasue all users are trained to use CUPC to manage their voicemail.
Sam
09-24-2017 06:15 AM
09-09-2011 06:41 AM
Hi Sam,
Cheers!
Rob
10-19-2011 05:38 AM
Rob,
Thanks. We implemented the solution. One note, you still have to have the users manually empty the Deleted items folder, changes the message option does not remove any exisiting deleted items folders already created.
09-26-2013 05:09 AM
We are running 8.6 and have the same issue. Anyone know if this has been fixed? We really do not want to delete them immidiately.
09-24-2017 06:17 AM
