Unity Connection/Exchange Question
Does anyone know if there is a way for Unity Connection to just forward a message to Exchange w/o setting up Unified Messaging?  Airgas has CME now and that what it is currently doing.  I was hoping there was a light and easy way to set this up without Unified Messaging
Hall of Fame Super Silver
Absolutely, setup store and forward under user--> message action.
HTH,
Chris
Re: Unity Connection/Exchange Question
Thanks Chris.  I set it up to Accept and Replay the message to username@company.com and I also set up a Smart Host (IP Address).  However the message does no seem to be forwarding.  Is there anything else I have to do to make this work?
P.S.  I do not have DNS setup in Unity Connection so I don't know if that's a issue or not.  I was thinking it would be fine since the smart host is setup with a IP Address
VIP Super Bronze
The Smart Host must accept unauthenticated SMTP relay from CXN's IP address. This is not a default behavior on most email platforms so be sure it is set. After that you can test whether it's working with run cuc smtptest from the CLI.
Please remember to rate helpful responses and identify helpful or correct answers.
Thanks Jonathan.  I will check with the Exchange guys on that.
172
