Community Member
Unity connection fails to add users
Hi; i'm running comunications manager business edition ver. 6.1.2 with unity connection 2.1.2; i made the integration and tested with two users created from the callmanager administration; the problem is that i can not create a user using the unity connection interface (in the user section does not appear this option) i can not change the password options in the user templates either, so users can not initialize their mailbox (this option appears as read only); the same situation occurs when accessing the axl servers section on the telephony integration. i'm using the default application user: ccmadministrator.
Thanks.
1 ACCEPTED SOLUTION
Re: Unity connection fails to add users
that is expected, i'd recommend you to go thru the whole guides in order to understand how this works
the changes need to be done on CUCM, under user management -> credential policy and credential policy default options
java
if this helps, please rate
java
www.cisco.com/go/pdi
if you're using a BE it's expected you do not have the add option in CUC, you need to read the CUCM BE guides to configure that system
Cisco Unified Communications Manager Business Edition
Maintain and Operate Guides
http://www.cisco.com/en/US/products/ps7273/prod_maintenance_guides_list.html
java
java
Community Member
Thanks, i have another question , the user Moves adds and change guide says that i can change the user template password from the unity connection interface or use the default password applied during installation, as i told you before, i can not change this password and i didn't set any password for user template during installation. The isntallation only ask for two passords: administrator an application user.
java
java
146
