UNITY Connection G.729a codec voicemail file on WIN7 and smartphones
I changed my voicemail file codec from G.711 to G.729a.
Once I changed it the I had to install Sl_G729a_setup.exe file on the subscriber (users) workstation using a Windows operating system and that a compatible audio player is installed.
everything works fine until the Windows7 and smartphones cannot play G.729a codec.
the question is?
Is there a Cisco solution to play G.729a encode wav file attachment on Windows computers, iPhone and Android phones?
308
