10-16-2010 07:03 AM - edited 03-16-2019 01:23 AM
Hi, I was able to create a VM for CUCM 8.0(2c) with VMWare Server by using the recommended specs from the OVA file. However, I can't get the hardware right for the installer to allow Unity Connection to run. I used the settings from the OVA file (see attached file):
160 GB SCSI Disk
2 GB RAM
RHEL 4
I have tried dual drives, single drives, 250 GB disk size, 2.5 GB of RAM, etc...But when I get the options for which app to install, I only get CUCM and CUCM-BE. It won't let me install Unity Connection. Any ideas on what hardware settings to use to get it to work?
Thanks.
Solved! Go to Solution.
11-03-2010 11:21 AM
Try 4GB RAM and 2 CPUs. I was able to get it working with this configuration.
Altaf
10-17-2010 08:37 AM
reviewing the CUC system requirements document, I notice that you need at least 8.0(3) version for virtual machines (and you're trying with 8.0(2)).
See:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/requirements/8xcucsysreqs.html#wp263612
Christos.
11-03-2010 11:21 AM
Altaf
