Community Member
Unity connection integeration to outlook
My email server is an google apps.
Through google syn users are accessing email via outlook
I am trying voicemail to be delivered to email?is this possible?
Re: Unity connection integeration to outlook
Esna has a product that can do this. It's called cloud link. I have not used it personally.
www.esna.com
Community Member
Is it possible to configure voicemaill?
Community Member
Anybody tried on this scenario?
Hi Shiva,
Check below threads , it might help you.
https://supportforums.cisco.com/thread/2100667
https://supportforums.cisco.com/thread/2027880
Rate all the helpful post.
Manish
Community Member
My emailserver is a google apps,will it be a possible to get in outlook
137
