Unity Connection Integration with Lotus Domino
I have Unity Connection 2.1 tha needs to be integrated with Lotus Domino 7.5. Can someone highlight the pre-requisite & config steps to be done in Unity? It would be very much helpful if someone also can highlight the changes to be done at Lotus side as well.
Rgds,
Partha
1 REPLY
Re: Unity Connection Integration with Lotus Domino
Creating and Configuring an Account in IBM Lotus Notes
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/user_setup/guide/2xcucus030.html#wp1049832
Try searching Unity connection + Domino on CCO if you're looking for information, you'll get several links
java
if this helps, please rate
java
www.cisco.com/go/pdi
169
