Community Member
Unity connection license
We are using Unity connection 1.2 in which we have got a license file for 100 VM users alog with 16 ports(which will be simultaneously active).
In the same license file we have got UNITYCN1-VM-USR for value 25.What does this exactly mean?
i am attaching License file for reference.
regds,
aman
1 ACCEPTED SOLUTION
VIP Purple
Re: Unity connection license
This is for an additional 25 users. So, you can support 125 VM users with this license file.
Hope this helps.
Brandon
VIP Purple
Hope this helps.
Brandon
Community Member
Hi Brandon,
We created 100 VM users.Accordingly,our licenses were consumed.
After that we tried creating more VM users but were unable to do so since the error message is coming "License Voilation :Subscribers".
It seems that we cannot create more than 100 users and 25 VM users as mentioned in Lic file , is something else.
regds,
aman
Community Member
Hi Aman,
The best way to find this out is to get in touch with your accounts team.Since they would have final say in it.
Having said that i would like to know if you have rebooted the server after installing the new license file(Which i think you already have done)
I am attaching a ppt from previous post if it helps.
Again Accounts team can best explain the Jargon
Community Member
Hi Brandon,
There was a problem in Licensing file.I received the new license file wherein I can add more users.
thanks.
regds,
aman
Community Member
Also(in UC 7.0) under System settings-->licences on the top right pull the drop down to look at "view license usage" what does it say ?
231
