01-26-2014 04:32 AM - edited 03-16-2019 09:26 PM
Hello all,
We upgraded our CUCM 6.x, Unity 2.x from MCS to UCS 9.1.
We got one license file from license team which uploaded into ELM page successfully. License Team confirmed that issued license contain cucm & unity connection both.
My question, after uploading license into ELM page, do we need to add additional license into Unity Connection also (as we use to do in earlier releases for VM Ports, VM Box, CTI) ?
Because we are getting license expire notification on the main page of Cisco Unity Connection.
Solved! Go to Solution.
01-27-2014 07:34 AM
Hi Anis,
+5 to my friend Aman here for his diligence!
I would try going to the COS that these users are tied to
and turn off anything related to Speechview. You need a
special license to use that feature which it looks like you
don't have.
Once completed - re-synchronize
Cheers!
Rob
"Seek it out and ye shall find "
- OneRepublic
01-27-2014 07:56 AM
Hi Rob,
thanks for sharing the info.
Are u referring to
So, u are suspecting this could be enabled which I was seeing 70 [Not In Complaince] but ignored it.
regds,
aman
01-27-2014 08:08 AM
Hi Aman,
Yes, that would be my best guess here
As Speechview is a licensed feature, I believe the fact
that it is checked on the COS is what is causing this issue.
Cheers!
Rob
- OneRepublic
01-27-2014 09:12 PM
+ 5 for my dear friends Rob & Aman.
Thank you so much for your findings & advises.
What i understand from your suggestion that notification is appearing because of Speechview configuration & it should not have any impact on system, the system should work fine with current license ... is that right ?
Anis
01-27-2014 10:05 PM
Hi aman,
I just found Connection Conversation Manager is stopped & IVR is also stopped working.
Anis
01-27-2014 10:19 PM
Hi Anis,
Did you try starting these services?
Also, did u check whether "Allow Users to Access SpeechView Transcription Service" is enabled or not as Rob suggested.
regds,
aman
01-28-2014 10:24 PM
Hi Aman,
License notification disappeared after doing work around as rob suggested.
Thank you rob for tip
Now I am working on Unity to bring it back to normal. Will update you once it fix.
Anis
01-29-2014 12:17 AM
Hi Anis,
thanks for update.
[+5 ] to Rob.
Can u share the licensing snapshot now ?
regds,
aman
