Unity Connection mailbox recovery
I have Unity Connection 7.1.3.  Is there a way to recover a mailbox?  I accidentally deleted a user with mailbox and try to restore it from backup but it does not have any option to restore a mailbox.  I do not want to restore the whole server in order to restore a single mailbox.
Please helps.
Mark
1 ACCEPTED SOLUTION
Re: Unity Connection mailbox recovery
The only way to restore a single mailbox is if you have configured COBRAS to backup selected users/mailboxes/messages.  Otherwise, the answer is no.  If you use DRS, it can backup each component individually but it restores the whole backup to the system.
Hailey
Please rate helpful posts!
Hailey
Thanks for the information David. IMHO,  it is odd that Cisco left off such an important feature in DRS.
Mark
I've heard that feedback before, so I understand.  On the flip side, DRS isn't really built for that task.  It's a complete backup solution in that you can choose large components of the system and get a complete backup of those.  It doesn't have the granularity built in to backup and restore specific objects.  But, it wouldn't be bad feedback to provide to your Cisco AM or someone that you feel would listen and pass the info up the chain.  The more Cisco hears something, the more likely it may someday get added to a features list.  In the meantime, if you feel you need to do that...then you can use COBRAS to backup specific objects.  You can even (based on your backup) restore as little as a single message to a user's mailbox.  Take a look at the COBRAS information at www.ciscounitytools.com and if you have any questions about how to make that work or what you may need to do to get things running...feel free to repost or even send me a private message.  I have some helpful info for you if you need it.
Hailey
Hi David,
Thank you for your valuable information.  I tried COBRAS and it works.  I also find a utility called DRS Message Fisher (you may already knew this) at CiscoUnityTool.com which aloow us to extract or restore voicemail message from the DRS TAR file directly. Not TAC supported but it works.
Mark
1039
