Unity Connection message pick up and drop
we have a cluster split between two sites.the cucm configuration directs calls to the subscriber first (via route list configuration). Is the message drop and message pickup always via the subscriber i.e if sub is in site y and pub is in site x and a user on site x leaves a vm - will the call always be handled by the sub in site Y , so message gets left to sub, transferred to pub(the primary) and then its replicated back to the sub?
customer asking why in active active mode cant the media be between the local pub in site x and a user in site x for example.
2 ACCEPTED SOLUTIONS
The call flow and message
The call flow and message handling is determined by how you route the calls.  There is no reason you can't set up a setup integration on CUCM for the local site and route those calls to the Publisher first vs. the Subscriber.  In fact, I've done this before as it makes more sense to localize the call as opposed to routing across the WAN.
Hailey
Please rate helpful posts!
Actually, yes - you can have
Actually, yes - you can have site X calls going to one server and site Y calls going to the other.  You would control that via the VM Profile and associated settings in CUCM...hunt pilot, hunt list, line group, etc.
In terms of colocation with CUCM, there isn't really a rule.  You can separate the CUC nodes across the WAN as long as you meet the clustering requirements and then integrate/register to CUCM as needed/appropriate for your environment.
Hailey
Hailey
Thanks David, once again for
Thanks David once again for a quick response - much appreciated.
Cisco recommend voice calls initially go to sub - so its just a recomendation , no technical reason. so this way message gets picked up or dropped locally to publisher and then only replication is done across the WAN . Main thing is that its one or the other - we cant have site x calls going to pub with site y calls going to sub at the same time.
Hijust a follow up - had a
just a follow up - had a look around but could not find this so just wanted to bounce this off you guys. Does the Unity Connection publisher have to be on the same site as a CUCM publisher? I cant see anything to say that it does but just wanted 2nd opionion. So in my scenario i want to have the cucm pub in one site with the cuc subscriber at the same site and the cuc pub at another site co located with some cucm subscribers,..kind regards....Jag
Hi JagYour deployment should
Hi Jag
Your deployment should be referred to distributed messaging with centralized call processing.
You can give a look to the following doc:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab09/clb09/vmessage.html#pgfId-1087499
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hailey
Thank you sir, much
Thank you sir, much appreciated.
90
