Unity connection migration
Howdy,
I'm intending to migrate a Unity connection 2 server to another box. If i do a backup first will i be able to restore all the data and greetings for each mailbox on to the new server?
Taff
Re: Unity connection migration
Yes, DRS will will restore everything.  Just make sure you rebuild the server with same hostname, IP address.  Also use the same restore point you used to backup.  I heard there was an issue if you used a backup point, then used a different point to restore.
I have tried to rebuild my unity connection 7.0.1 box on a VMWARE machine to test my backup files. But the restore failed at 67%, i have got some error on my restore.  i have attatached some logs. Can you help me about this issu.
Regards.
Pamela
222
