Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
UNity Connection: MWI ON/OFF not indicating
Unity connection & CCM is integrated properly & all the vocie ports are registered in CCM. I am able to send & read Voice Mails. Voice Pilot no is working fine. But the problem is MWI On/Off is not showing once msg is delivered or read out....plz suggest..
Re: UNity Connection: MWI ON/OFF not indicating
When you dial MWI on/off numbers from the phone does the red light comes up ?
For example the mwi on off numbers and 7001 and 7002. If you dial those numbers does the red light turns on and off ?
- check the setting under "Telephony Integration" -->"Phone System"
-also check Search Users ----> Edit User Basics ---> Message Waiting Indicators
Yes, from our phone system when we dial the MWI ON number it Glow & after pressing MWI OFF it goes...
Check your CSS and partitions for MWI lights on/off, VM ports and phones.
Voice mail ports should have access to MWI numbers and MWI numbers should be able to access phones.
Some more information about CSS and partitions:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/dialplan.html#wp1044276
User phones & MWI ON/OFF numbers are in same CSS & Partition...Still the problem is happening..any sort of help would be appreciated..
SUer phones & MWI ON/OFF numbers are in same CSS & Partition...Still the problem is happening..any sort of help would be appreciated..
225
