Unity Connection not Falling back to Secondary Server
I have an IP Telephony setup with CUCM 6.X and Unity Connection 7.X.
We have Unity Primary and Secondary nodes for HA.
But Unity is not fall back to the  secondary when primary fails. I can see that Voice mail ports are not registered when Primary falls back.
Where I can check for trouble shoot the issue.
Nithin Louis.
1 REPLY
Hall of Fame Super Red
Hi Nithin,
Can you check these settings in CUC for the "Secondary" server config. This would add the Sub
to the list of available CUCM servers
Step 32 On the Edit Servers page, do the following substeps if the Cisco Unified CM cluster has secondary servers. Otherwise, skip to Step 33.
a. Under Cisco Unified Communications Manager Servers, click Add.
b. Enter the following settings for the secondary Cisco Unified CM server and click Save.
Table 6-16     Settings for the Cisco Unified Communications Manager Servers
Field
Setting
Order
Enter the order of priority for the Cisco Unified CM server. The    lowest  number is the primary Cisco Unified CM server, the higher    numbers are  the secondary servers.
IP Address or Host Name
Enter the IP address (or host name) of the secondary Cisco Unified CM server.
Port
Enter the TCP port of the Cisco Unified CM server that you are     integrating with Cisco Unity Connection. We recommend that you use  the    default setting.
TLS Port
Enter the TLS port of the Cisco Unified CM server that you are     integrating with Cisco Unity Connection. We recommend that you use  the    default setting.
Server Type
Click Cisco Unified Communications Manager.
http://www1.cisco.com/en/US/docs/voice_ip_comm/connection/7x/integration/cucm_sccp/guide/cucintcucmskinny050.html
Cheers!
Rob
"May your heart always be joyful
And may your song always be sung
May you stay forever young "
- Dylan
116
