Unity Connection Overlay Upgrade
Got a question. If you currently have a Unity Connection 8X using say a 1,000 user overlay and wanted to upgrade to a 5,000 user overlay, what's the process of the upgrade/migration? Do you do your usual DR Backup and build a new VM with the 5K OVA template with the proper licenses loaded and then do a DR Restore? ...or am I off.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Unity Connection Overlay Upgrade
correct, it simply requires higher hardware resources, so either different MCS server or OVA template.
Thanks Chris.
230
