Community Member
Unity Connection Password Expire Bug?
I'm running into an issue where random users are prompted to change their password even though the "User must change password on next log on" setting isn't checked. I think its stemming from turning off password expiration.
This is for the voicemail password. Anyone else run into this issue? Temporarily I enabled password expiration then disabled on the authentication rules so I'll check in with users tomorrow.
Hall of Fame Super Red
Re: Unity Connection Password Expire Bug?
Hi Tim,
I did see a bug that was in UC 2.x that when passwords were set to "never expire" you would be prompted daily to reset the password. The workaround was to set the password expire to 365 days. Does this sound familiar?
Rob
Community Member
I'll give that a shot and see what happens thanks for the input!
179
