Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
tka
Unity Connection Port types
Hi All,
Could some more explanation avout Unity Connection port type :
1) MWI : OK
2) TRAP : Telephony Recording and PlatBack , is an incoming or outgoing port or both ? do we use TRAP when we access and record messages using the phone handset ? what about when using viewmaiL Web client, do we ports or no ?
3) Message Notification : What king of notification ( I can't see the use)
4) Answer Call : answering calls include when registering message ? or playeinh auto-attendant ? the difference with TRAP ??
best regards,
1 REPLY
Hall of Fame Super Red
Re: Unity Connection Port types
Hi Ramzi,
Good question!
**Answer Calls - When a call is forwarded to UC these Ports answer the call and play the user Greeting;
Check this check box to designate the port for answering calls. These calls can be incoming calls from unidentified callers or from subscribers.
Message Notification - Call to Outcall device (like Mobile) to indicate new messages for Subscriber;
Check this check box to designate the port for notifying subscribers of messages. Assign Message Notification to the least busy ports.
**Dialout MWI - Must have to turn On/Off the RED Message Lamps
Check this check box to designate the port for turning MWIs on and off. Assign Dialout MWI Requests to the least busy ports.
TRAP Connection - TRAP Connection - One such application is the Media Master Control;
Check this check box so that subscribers can use the phone as a recording and playback device in Cisco Unity web applications and e-mail clients. Assign TRAP Connection to the least busy ports.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/integration/cucm_sccp/guide/cuintcucmskinny020.html
Hope this helps!
Rob
343
